RMS Ratings and questions
My subwoofer is a Kenwood KFC W3012..Which is 1200 Watts Peak Power and 400 watts RMS and is 4 ohms. And i am only get one of them.
Will this amp be perfect for it? http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER
No, that amp will under power the sub, and it's not ideal because its a 2 channel amp.
It's not ideal because 2ch amps tend to cost more than mono amps, and since that Crunch amp is an A/B class, it is more inefficient than a mono class D amp. Which mean it will put more of a strain on your electrical system (although for this little power it probably won't matter too much, just something to keep in mind)
Don't know where the whole "1 channel means i get 700 watts" thing came from. If you get that amp and only use one channel, you'll still only get 87.5w RMS or whatever (again that 350 means nothing since its a PEAK rating, and it's for a 2 ohm load). If you bridge the channels, then you'll get your 350 RMS or so. Maybe you know this and I'm just misunderstanding you lol.
