RCA cables melting!!
Old 05-20-2008 | 05:51 PM
macbeth18288's Avatar
Default RE: RCA cables melting!!
..oh geez
Old 05-20-2008 | 06:37 PM
enigma34's Avatar
ORIGINAL: macbeth18288
..oh geez
What's.. oh geez?
Old 05-20-2008 | 06:41 PM
i think you went in over your head for your first instal. read up that link to the stereo stuff!!!!!!
id like to help ya out but ya sound like one of my old friends that i just want to push out of the way and say NO NO NO thats not how ya do it just watch me.LOL not trying to be mean... just saying.
Old 05-21-2008 | 06:29 AM
enigma34's Avatar
if my LPF is woking fine, how come if i set it at full or Hpf it gives me a problem?
Old 05-21-2008 | 07:36 AM
I'm not sure if this is an issue here but since you don't own a wire stripper (and when you don't have dental insurance, buy a wire stripper!)-- You must use a terminal crimping tool to put ring terminals onto wires. Mashing them with pliers is never acceptable, you get a bad connection.
The subwoofer amp should be set for LPF (Low Pass Filter = passes no high frequencies --> only bass). The main speakers should be set for HPF (High Pass Filter = No low frequency --> no bass). Some equipment has a "subsonic" filter option to help with the "breathing" effect, but it's probably still a poor ground or bad RCA cable doing that to you.
Old 05-21-2008 | 12:47 PM
enigma34's Avatar
ORIGINAL: enigma34
Its all working awsome now, everthing is good. The ground is good. and it was the hpf that was working, thats what i had it on. now everything is working, i have it on lpf. And my head unit has this options, i think its say's 5w L, and if i turn it up my subs come alive!!!!! I think the problem was that my wires where touching, (That is why it was breathing)i had like the ground, rca, and power cable on top of eachother. i ran the power cable on the opposite side of the car, and the rca and h unit turn on, on the other side. when everything meeted in the trunk it was a mess, so i spreaded them apart.
none of the wiers are hot to the touch.
Now i just need to find a way to keep my license plate from making noise.You cant here it inside the car, but out side omg!!. any tips?
Old 05-21-2008 | 02:15 PM
use double side adhesive and put padding behind it
Old 05-21-2008 | 03:19 PM
ya double sided tape, or foam tape that is kinda thick/stiff.
you can also use a hot glue gun. yes im serious! i use it on my 99 with the foam strips behind the liscence plate.. just clean behind the liscence plate and the back of the plate. then put the foam strips on the back of the liscence plate runing along the top and bottom 2 strips at least... then put some hot glue behind the liscence plate, and around the bolt or loose bottom just slide and quickly put the plate onto the car and tighten down the liscence plate and hold the plate to the car for afew mins allowing the hot glue to cool and stick and get hard.
works great IMO..... dont worry about the hot glue because you can still pick it right off the car with no left over residue if it pops loose
i was pumpen my old 12 with 1600watts, and currently 2 12s with only 600watts for now. still very little rattling.
croninc
03-10-2009 07:41 PM
TheFrequency
02-22-2009 09:44 AM
enigma34
01-13-2009 09:09 PM
xsdudztx
08-02-2007 12:59 PM
SPLAT
12-11-2006 07:06 AM
