Radio Shorts Out
Old 04-21-2008 | 09:15 AM
ghosttech's Avatar
Default Radio Shorts Out
OK well this is the issue i am having resently for the past month and half everytime i have the music loud the radio cuts off and restarts its self or if i have the bass high also cuts off i have checked the fuses and they are all ok can anyone help me with this
Old 04-21-2008 | 02:34 PM
imshirazy's Avatar
Default RE: Radio Shorts Out
what's your car, your setup, etc.
you need to tell us a lot more
Old 04-21-2008 | 03:01 PM
macbeth18288's Avatar
Stock radio? Aftermarket?
What are you running???
Old 04-21-2008 | 03:56 PM
KarTuneMan's Avatar
Ditto, and ditto!
Old 04-22-2008 | 06:06 AM
ghosttech's Avatar
Sorry about that i have a 94 civic ex coupe with a 99 vtec motor Y8my setup is alpine head unit it is ipod ready which i have in use i also have 2 type R subs i have disconnected the subs to see if it was the cause for the short but still same thing i have also disconnected the amp nada i have a Optium battery Yellow top soo i know it cant be that so does any one have any ideas thanks in advance
Old 04-24-2008 | 02:36 PM
KarTuneMan's Avatar
What voice coil configuration on the type R's, and how are they wired....and what type of amp?
Also, try using your amp turn on from your deck to trigger a relay.....to turn the amp on.
Old 04-24-2008 | 02:40 PM
Have there been any other parts of the car that have had a sudden loss of power?
Any problems starting?
Gauge lights dimmer than usual?
Check your battery connections just to make sure that they are solid.
Old 04-28-2008 | 11:41 AM
ghosttech's Avatar
you know what when i brake the head lights do dimmer but get power again and at time the dash light is out but not much if its the battery connectors i should replace them with what longer ones since i have the optium or what but again the radio knocks out well really it reboots its self after a certain vol or bass not sure why theRadio is a
ALPINE CDA-9856
Old 04-28-2008 | 12:35 PM
T3rry's Avatar
Member
sounds like a bad alternator or ground cable from the battery
Old 04-28-2008 | 01:01 PM
ghosttech's Avatar
really so if i swap out the alternator it should work better and not have the issues i have been having and if its the ground then i will swap both positive and neggative but what is a good brand for an alternator
