Puttin Stero System In (HELP)
Heyy everyone,
Yesterday i got my first car,
i got a 1990 Honda Civic Si,
everythings great with it, exept one thing.
Stock Stero,
Casset tape ****ty deal.
I was wondering how to put a Cd player and hook up some new speakers and **** in it.
Thanks,
XxDrummerxX
Stock Stero,
Thanks,
XxDrummerxX
RE: Puttin Stero System In (HELP)
wow '90
well, i don't have the specs of your car in front of me at the moment, but I am sure you can use our fancy search button or google's search and pull the instructions right off the internet
most of the time you can just drop in a new headunit depending on your civic pop the one thats in there out and take a look then for speakers you might have to finda diagram for em
Ive installed 3 different stereos into my car. 1 had to do twice cause i swapped dashes. I know that for me its just wires hanging loose behind the center bezel. If you take that thing off (4 screws) you should be able to see where the wires go. I know know if the OEM had a harness or what. from what ive seen most people just cut the wires strip and splice to the new head unit. I think you will have to get a instal kit too. I know when i got my car it came with a black trim peice that makes everything look good in the hood.
Get a harness adapter! Don't cut the wires in the car! It's so much easier.
If the stock speakers are still OK you can just start with a new head unit until you have time and/or money to do the speakers. The head unit is standard DIN size so no install kit is necessary other than the harness adapter.
