ohm??
ohm??
the subs i want have 2 different ohm's. what does this mean? one has 2ohm+2ohm and the other has 4ohm+4ohm. i really dont understand what this means or which one is better. what should i go with? they are both the same $. this should probably be in the audio section, but i thought i was in it and i posted it here. sorry but now there is nothing i can do. maybe you can still help me out.
RE: ohm??
the speakers are dual voice coil. 2+2 can be bridged down to 1 ohm and 4+4 can be bridged down to 2 ohms. it is according to what amp you want to use. if you have and amp that is one ohm stable get 1, (2 ohm dvc) or 2, (4 ohm dvc).
RE: ohm??
ORIGINAL: jhsplaya08
RE: ohm??
well i havent got them yet but i am going to get them for christmas i think. im looking at the alpine type r 12's. i want to get 2 and im not really sure about the amp. any suggestions? i want an amp that has the power to push them hard and i was looking at the v12 series just not sure about what wattage or anything else...?
RE: ohm??
haha wow sorry..i was thinkin you wanted to get a 2+2 and a 4+4. I was like..what reasoning for that, anyways...
personaly, i think you should get 2 10" 2 ohm type-r's and 2 and 2 MRP-M350 amps. a very beautiful amp. that i personaly have in my civic. delivers perfect power. stick that with an alpine deck with a bass engine and your good to go.
iv got that amp. to a kicker comp with an alpine deck and it sounds amazing. people are shocked at what a single 10 can do.
RE: ohm??
If you get two dual four ohm subs, you could run them in parallel at two ohms each and get a total ohm load of one, assuming the amp can run one ohm stable...
Or two amps at one ohm each by running the two+two subs wired for one ohm each...
