need audio/sound help
hey guys, i hav a 99 civic.. i really wanna do sthg with the sound but dunno where to start.. someone care to help?
atm ive got default sound for everythg cept ive changed the stereo to a pioneer mp3 deck.
RE: need audio/sound help
personal opinion, although i dont know whaty kind of $ your dealing w/, if you have to get it peice by peice, i'd get sm realy gd spkrs next, and you can run your spkers in sequence with 2 per channle w/o dropping the resistace, for ex if you have rear deck mounting, after speakers then get an amp to power those speakers, then you top it with sub woofer, which can easily cost as much as the rest of the system combined
no but it wont hurt........an aftermarket unit is going to put much much more power out to ur speakers. It will also give you the ability to play with the equalizer a LOT more. This way you can have it sound JUST like you want it.
I'd definately invest in a good set of aftermarket speakers first. Once you do that, I think its a matter of personal opinion. If you feel you have ample mids and highs at your usual listening volume, but you notice that the speakers crack when you try to add some bass, I'd say go for the sub. Depending on how much power you want thru your subs depends on how much you spend. If you want high wattage though, you definately will have to shell out some cash for a good sub amp. I think that a decent sub and amp combo will fulfill that bass you need and for the most part a good set of after market speakers will produce the mids and highs youre looking for. I think, later on down the road you can invest in a 4 channel to power the speakers, and probably a capacitor at that point just to protect your alternator. As far as brands go, alpine has some good stuff and so does infinity
its a bit of personal and not. your gonna be alot better off with a pioneer then sony or dual, but you can get alot better for the same price
if you are just replacing the speackers, you dont need an aftermarket unit. one of the good things about an aftermarket unit is the power, so its much better off if you replace the deck as well.
brands- PG, RF, JL, Blauhpunkt, Kicker, alpint
Civic Si 00
02-26-2008 06:22 PM
cinefyl
05-21-2006 12:54 PM
