lose trunk weight?
lose trunk weight?
I have 2 12'' Visonik powered by a 600w xplod amp. i might get a new amp.
here is the spec on my subs
1000 Watts Power Handling (500 Watts Each)
500 Watts RMS Power Handling (250 Watts RMS Each)
Frequency Response: 20Hz-300 Hz
I want to get somthing lighter like a single 10'' or 12'' already in a box.
i figer i single is lighter than my two 12''?
You think upgrading to a good 10''/12'' is better than my 2 cheap visonik subs?
$200, but i want to buy a sub that has its own box. I like kicker, i here not to get there comp subs. And i here you guys like the alpine. and i think i want a 12'' but ill let you guy's deside on what i should get. and for an amp ill get one that can get me the most out of my one sub.
i piad new $170 for the 2 visonik subs with amp and wire kit , so just a single sub for around $200 should be a nice improvement?
Believe me, the install is a HUGE part of car audio. If you're willing to build your own box, it's worth it and not hard. Just straight cuts, screwing and gluing.
If not, go to best buy or somewhere and listen to as many subs as you can preferably in the box it comes with or whatever
edit: also if want to get an Alpine type R (quite good), buy it on ebay or woofersetc.com.....maybe evey craigslist...Just shop around cause you can find them for cheap
Gets quite loud, but is lacking in the sound quality department.
What's wrong with buying a kicker with a box made for the sub by kicker?
Idk if it was a type r, but I saw an alpine only came in 12" sub that's like the same price as the L7 but it was 3000w, L7 is 1500w. Is it lowere quality?
I lisin to mainly rap and have my volum up good. Should I get a 10" or a 12". I here the shape of the kicker solo 10" sound like 12" and 12" sound like 15"?
