light action (even more pictures!)
ok so i am gonna buy a cathode kit and of the prewired LEDS from oznium.com now for the cathode kit i know i can go straight to the fusebox as the power source. but as for the LEDS i dont have 4 extra fuse slots for those. can i use the cigaratte light as a power source because the leds are going into my vents and the cathodes are going down underneath my dashboard.
how do i wire them up? is the fuse box the right amount of power for the cathode kit?
RE: light action
wow thank you a ton windcalmer that was pretty much exactly what i needed. so is it virtually the same if i use an empty fuse slot on my fuse box? also are the cathodes and leds really bright? are they too bright to drive with at night?
RE: light action
So exaclty how bright are these things? lol
I just purchased a 12" kit, with about 8 LED'S to put in the air vents and stuff.
Hopefully the 12" kit will be good enough to light up the floor on each side of the front....
RE: light action
The 12 inch kit will be fine for the foot wells. It is really bright, but not so bright you can't see anything at night i actually have a 12 inch cathod and a 12 inch neon under each well, and mines like perfect, not to brioght and not dim at all.
RE: light action
yep well i got them today but one of the cathode tubes was broken. so i emailed them to see if they could ship me one more to replace it. the wireing was insanely easy to do also. i will post up some pics tomorrow.
