LED Strips for RPM
LED Strips for RPM
LED Strips
I just received these LED strips. I think if I were to do another one, I would do the whole climate control with these. No need to solder resistors, very little cutting of the plastic peices. I also think the temp dial would light up a lot better too. The brown strip is paper thin with a sticky back. Almost like a ribbon. These run about $12.50/foot. The other style that has plugs every 3 LEDs is the one I would use for the buttons. Just cut them to the right length, hot glue them on the board, and solder the (+) (-) wires to one of the bulb sockets. That simple. These are about $10/foot. Both of these strips are not quite as intense as the 3000mcd single LED's, but they are good enough. Even better when you replace the buttons with new, clean, and bright ones. (Elmhurst has the set for under $60)
http://www.tradekey.com/ks-led-strips/
why would you make up a fake story to advertise your product, and then make your user name give away that you aren't actually a customer?
read the rules man, they address what to do if you want to advertise on the site.
DITO.... very foolish.
OZNIUM > You
and www.OZNIUM.COM can kick your @ss when it comes to lighting upgrades!
OZNIUM > You
dito.... Very foolish.
Oznium > you
and www.oznium.com can kick your @ss when it comes to lighting upgrades!
Oznium > you
phillywilly
04-03-2011 08:40 AM
addiction2bass
07-11-2007 12:08 AM
