LED Install
#31
RE: LED Install
ORIGINAL: tha_next_Kobe
i'm wondering if i even need to run a fuse from the switch to the power source because i used my amp as my power source which already runs a fuse to the battery
#32
RE: LED Install
Put it this way, I owe my life (ok maybe thats a bit extreme, I owe my neons) to a $2 fuse that I managed to blow when I was installing them. For how much they are, they are sooo worth it. As the saying goes "Id rather pack heat and not need it rather than need heat and not have it". That 1 time in 100 when you do need a fuse and dont have one, you will regret it.
Edit: Neons is used in the collective term to generalise all interiorlights consisting of both cold cathode and LED.
#36
RE: LED Install
ORIGINAL: 03civicwilkz
Thanks I figured thats what it was i just didnt know.
#37
RE: LED Install
ORIGINAL: Chaos
Yea the DIY is good but I think its a bit too brief for the amount of information covered. I think a little more detail would have helped.
Damn what else should I have put in?
1. Disassembly of the dash and all.
2. ?????
Let me know.
#38
RE: LED Install
I personally was just wondering about the fuse set up...other than that the entire DIY is great dude...dissasembly of the dash is pretty easy and straightforward...unscrew screws and remove...plain and simple...i thought it was thorough dude...it helped me out a ton! thanks!
#39
RE: LED Install
some one should Def. make a detailed thing on this with pic's and everything....it would help out alot for people who dont quite understand what to do...like myself lol because i want some sweet interior lighting. thanks.
#40
RE: LED Install
well if your looking into any just QUICK/EASY light bulb changes then this is a good place to buy...
http://www.superbrightleds.com/
BUT if ya can do some wiring yourself this is the BEST place to buy from.......
http://www.oznium.com/
oznium is usualy the most recomended place cause of thier sweet @ss products and customer service! but you do need alittle wiring knowedge....
but with the superbrightleds site they are more for just pull out stock bulb and insert new led bulb units. great for the beginers or just the lazy people
addiction2bass
Interior DIYs
09-25-2008 11:41 AM
