keyless entry wiring question
Old 06-27-2006 | 09:05 PM
khanselman's Avatar
Default keyless entry wiring question
So, I purchased the Autoloc CK2000 automatic door lock system and installed it on my 02 Civic DX.. took a long time (especially when I can only work on it when it's not RAINING!) with a lot of modifcation but it finally works.. now I am trying to setup the Keyless entry to flash my parking lights whenever I hit the button, which is a feature it says it can do. Looking at the wiring diagram I am a little confused.. I think I have to buy the Autoloc RA800 relay for it to work, but I was just curious if anyone knows how I can go about doing it without the relay?
attached is the wiring diagram that is the only instructions they have for it..
[IMG]local://upfiles/10011/B4EA5BEC79954EAD91BF62D815F63528.gif[/IMG]
Old 06-27-2006 | 09:36 PM
05reverb's Avatar
Default RE: keyless entry wiring question
it's very simple, do you have that kl400 orange wire comming out of your door lock system? if so, you just need to purchase a 5$ bosch relay and connect it like in the picture, make sure to check if your car has a negative trigger, if so you'll have to change the 30 pin on the relay and connect it to ground.
Old 06-28-2006 | 10:13 AM
khanselman's Avatar
yeah, the relay wasn't that expensive, probably around the same price.. I just was wondering if it could be done without a relay?
Old 06-28-2006 | 08:33 PM
05reverb's Avatar
nope, you need the relay cause the parking lights is too much of a load for the orange kl400 wire, so you need the relay.
Dave97Snake
03-07-2012 03:06 AM
Shbek
10-21-2007 07:59 PM
silverbullet01
18
05-20-2007 06:11 PM
97_ex
04-26-2007 08:44 AM
97_ex
03-21-2007 12:48 AM
Quick Reply: keyless entry wiring question
