Ignition Wire!
RE: Ignition Wire!
Should be black w/yellow stripe
Remeber though that, that is a true ignition wire not an accsesory wire and this wire will stay 12V while the engine is starting and will not be powered up when you click the key once to the first ACC position to only have the radion on.
RE: Ignition Wire!
OH yeah, I got carried away telling you about it and not where to find it. You will need to drop the driver side dash down and it will be wrapped in black plastic tubing going from the steereing column to the fuse box. You might have to pull the big metal peice down being held by 2 10mm bolts but you can work araound it also.
asdfbrendan
08-24-2007 02:41 PM
xsdudztx
08-14-2007 05:45 PM
xsdudztx
08-09-2007 07:45 PM
jds62f
03-07-2007 09:49 PM
