I don't know if this is a DIY or not but...
Old 01-31-2006 | 09:28 PM
Cutt's Avatar
Default I don't know if this is a DIY or not but...
After being ask a few times in post and pm's I decided to write this. This is how to built a nice custom box in the back of your EG hatch and save space. If the mod's thinks this is good anough the can sticky it. If they want to make any changes to it that will be fine as long as I know first.
Take everything out back there. Tire, jack,tools and anything else you got back there which will be more weight then a box and sub. I can't think of the name of it but you will need some of this spray foam that is yellow and seals really hard and stong when it dry's. You can get it a Lowes. Then you need just the wood that is used to make boxes. After you get you sizes and box built and ready to go in. Spray some of that foam around in there and place your box in. Let that all setup and dry then spray some inside the box everywhere that needs sealed but be sure you can get you speaker wire in. Then put you carpet back in over the box cut your hole and place your sub in and call it a day.
Old 01-31-2006 | 09:51 PM
mxs's Avatar
mxs
Default RE: I don't know if this is a DIY or not but...
This needs a little more information and some pictures before it can be a DIY
Old 01-31-2006 | 09:54 PM
Cutt's Avatar
Ok sorry. I didn't think to take any pic's because I didn't really think people would care that much about making one.
Old 01-31-2006 | 09:58 PM
mxs's Avatar
mxs
it's okay, anything useful can be turned into a DIY, because somebody out there will want to do it.
Old 01-31-2006 | 10:00 PM
Cutt's Avatar
yelp I will remember that next.
Old 02-01-2006 | 04:01 PM
bobbytonic's Avatar
I remember reading somewhere that the odor giving off by that foam expander stuff while it cures can eat away at your subwoofer surround. So if you do use it to spray inside the box(which is rather pointless if you build a box worth a crap) make sure you wait a couple days before placing the sub inside the box
Old 02-01-2006 | 04:36 PM
Cutt's Avatar
I did it for just incase it needed sealed a little better.
PremierCivic
09-27-2010 07:35 PM
knight101
16
08-06-2010 08:43 PM
Luke_Jones
12-02-2007 03:33 PM
Benny
05-31-2007 10:13 AM
RedlineZero
09-08-2006 11:28 PM
Quick Reply: I don't know if this is a DIY or not but...
