help with wiring problem
Old 04-05-2008 | 11:13 AM
MAKIN_A_KILLA_HATCH's Avatar
Default help with wiring problem
ok, well... i recently bought a 1991 honda civic 4-door car. some of the wiring clips were cut , and im trying to find a wiring diagram for the inside wiring harness, if anyone knows were this can be found please let me know. also if there is a way to skip some of these wires i dont mind losing some of the features i just want to make the car run. If i cant get it torun etc. etc. it will be crushed, and no1 likes to see a good honda go lol thanks in advance for any help.
Old 04-06-2008 | 05:09 PM
KarTuneMan's Avatar
Default RE: help with wiring problem
What harness are you speaking of? There are alot of them to choose from. Main ignition harness? At the key or down the fusebox area. More specific info needed.
Old 04-06-2008 | 05:13 PM
there are wires cut around the fuse box areathey are leading toward the back of the car. im assumming those wires are for taillights, fuel pump etc.. i have most of the wires attached through the rest of the car. im trying to get to a junkyard to look at another civic and see what i can tell from there.
Old 04-06-2008 | 05:51 PM
i also tried to download a helms manuel but had no luck there
Old 04-06-2008 | 11:21 PM
01civicsed's Avatar
You can look around to see if you can match up colors and stripes, but make sure they are all the same size and color. If you can't do it that way the other best way is to test for continuity using a digital 12 volt multimeter (which you can get at wal-mart, Innova was a good one), set it on the setting that most resembles a speaker and test fromthe end of thefuel pump wiring going into the fuel pump with one lead(under rear seat probably)and then testing the wires in your cut harness with the other leadand listen for the meter to beep. Do not hook up any wires that you cannot test. If thats not possible, see a mechanic or other ASC/MECP certified technician. Good luck hope that helped some!
Old 04-07-2008 | 10:28 AM
thanks for the suggestions, and i think i try to match color to color wires. ill keep every1 updated
Old 04-07-2008 | 12:43 PM
If you have access to a parts car, switch the whole harness out. You will have to pull the dashboard to do that, which actually isn't as complicated as it sounds. Even if you're going to splice the wires it will be a lot easier to see and do it with the dash out.
Old 04-08-2008 | 03:29 PM
well thank you all for your help, but i traded the civic for a accord because i hated to crush the car. hopefully i will get some updates on the accord later, also thanks agian to every1 for your help. this topic can be trashed.
buckley03
09-08-2008 07:18 PM
megafandrew
08-30-2008 08:54 PM
PunisherInOKC
05-22-2008 12:52 PM
95civic1.6l
12-23-2007 01:10 PM
redmachine07
05-10-2007 12:22 PM
Quick Reply: help with wiring problem
