Help with speaker and deck
How do you properly removed the deck?? What I do is get two philip screw driver and pull it out from the side but im not sure if im doing it the right way cause once you start pulling it forward you will hear a lot of cracking noise. Second how do you removed the rear speaker??? Its a 94 EX coupe by the way.
RE: Help with speaker and deck
usually aftermarket radios come with little tools to help remove the radio. i never removed a factory deck on a eg.
the rear speakers are bolted in from the bottom in the trunk. lay your back seats down, look up under the speakers and there will be like 4 nuts holding each upolstered speaker cover on, remove those and the speaker will be screwed into the upolstered cover with 4 screws.
cowsgonemadd3
02-20-2008 06:30 PM
