help with amp wiring
Old 01-15-2008 | 05:13 AM
legal's Avatar
Default help with amp wiring
i got the dual 750 wat amp. and it never goes off.
how do i wire it to where it goes off when my car goes off
lol im tired of having a dead car all the time haha.
&whats a good way to hide my wires.
Old 01-15-2008 | 05:25 AM
My04Civic's Avatar
Administrator
Default RE: help with amp wiring
uhh...you should have the power going from your amp, to an inline fuse, then to the battery, and have a good ground coming from your amp as well. from what i know, the amp should turn off when your car turns off. that doesnt make any sense.
Old 01-15-2008 | 06:10 AM
legal's Avatar
its something with my remote wire.
its not hooked up right.
Old 01-15-2008 | 07:10 AM
My04Civic's Avatar
Administrator
what color wire do you have the remote wire hooked up to? it should be hooked up to blue
Old 01-15-2008 | 08:08 AM
You need to run a single thin wire from the remote terminal on the amp to the "amplifier turn on" lead on the back of your head unit. Some RCA cable assemblies have the wire molded in between the audio cables. Usually it is a blue wire from the head unit but check your manual or the sticker on the unit to be sure.
Old 01-15-2008 | 09:06 AM
Littlehag's Avatar
If you have an aftermarket cd player it will be a blue wire comming out of the back of the unit. Normally it's blue, I can't say always because i'm sure there are some manufactures that just want to be different. as long as that's hooked up you should be good to go. check to see if you have power at the amp (remote terminal) when you turn the ignition off. If you do then trace the wire back to the head unit and see if there is a problem there.
Old 01-15-2008 | 02:29 PM
imshirazy's Avatar
ORIGINAL: Littlehag
It's actually always blue
YOu simply have power going through it of course
do as they say and trace it back to see where it's coming from
if there are no cuts in the blue wire, you may have an amp or HU problem
Old 01-16-2008 | 05:19 AM
legal's Avatar
what i got going on right now is i have 2 clear medium guage wires going into this 2 hole into 1 hole deal the 2 clear wires from 12v and rem. are pluged into the 2 holes and then the 1 hole is connected to the big thick blue wire that goes to my battery.
Old 01-16-2008 | 05:24 AM
My04Civic's Avatar
Administrator
ORIGINAL: legal
dude...what the hell? we need you to post pictures of everything. there should only be these wires.....as follows: Ground, Power, REM(remote), and speaker wires, coming from your amplifier. ground to ground, power to inline fuse, to + battery terminal, REM to blue wire behind head unit, speaker wires to sub(s).
Old 01-16-2008 | 05:38 AM
legal's Avatar
haha i know its confusing me as well.
ill take pictures of it after school.
