Guess what amp has 1250 watts rms per channel
just picked up a new amp running 1250 watts rms per chanel 2 chanel amp can be bridged to 1600 watts rms at 4 ohm and its one ohm stable hmm i wonder what its gonna be powering lol
RE: Guess what amp has 1250 watts rms per channel
hope its a class D amp.... or ya have a power house to back it up.LOL
i like my mono orion D2400 1200watts rms. coulda just bought a larger D5000 i think.. for 2500watts rms
Oh shes class d all the way lol heres the actual specs
12.6 Volt Power Output Specifications
600 WRMS per Channel @ 4 Ohms and ≤ 1% THD+N
900 WRMS per Channel @ 2 Ohms and ≤ 1% THD+N
1250 WRMS Bridged Channels @ 4 Ohms and ≤ 1% THD+N
14.4 Volt Power Output Specifications
840 WRMS per Channel @ 4 Ohms and ≤ 1% THD+N
1250 WRMS per Channel @ 2 Ohms and ≤ 1% THD+N
1600 WRMS Bridged Channels @ 4 Ohms and ≤ 1% THD+N
ORIGINAL: 91_CIVIC_ZC
maybe you should REread those specs and without a high power alt expect only a 12volt or less voltage while bumping.LOL
throw in a fullsize battery in thier and it may be able to hold a 12volt range... i know my stock little battery would dip down to 10volts so easy!!!
tho i just trimed down a side of my optima yellow top to clear the AC bolt, and UCA bolt. preaty minor cut and still a TIGHT FIT.LOL but my voltage holds a strong 12volt now!
johnb
09-04-2007 06:52 PM
addiction2bass
01-16-2007 12:55 PM
