Engine Noise with 4channel amp????
Old 01-16-2008 | 03:49 PM
civicduty96's Avatar
Default RE: Engine Noise with 4channel amp????
ORIGINAL: imshirazy
ORIGINAL: civicduty96
ORIGINAL: imshirazy
try grounding the shield of your rca lines..... pioneer head units are well known for creating ground loops
It's not actually because they cause ground loops
It's because the couplings in the back of their head units (which all head units have) which have the purpose of resisting the whining noise, tend to blow when the RCA's touch anything with even a small electric charge, as small as a car static shock.
So indeed try this
Ground the shield of your RCA anywhere to your car and see if it stops.
If not, you probably have a bad ground connection, and it might not be your amp.
Now you say you tapped into the speaker wires in the back of your head unit?
In all honesty, you really should be using RCAs in the first place. Use RCAs as well and see if it solves the problem.
when that happens it opens up the ground which is supposed to be there.... creating resistance between the headunit and the amp...AKA ground loop...
and i do believe he's using rcas .... he's tapping into the harness so he doesnt have to run wires into the door
Don't you mean disconnects the ground not opens it up?
do i need to explain what a open circuit is ...... think about it...... open = no continuity...... closed = completed circuit ...aka continuity
Old 01-16-2008 | 07:13 PM
imshirazy's Avatar
what the hell do you think I said????
jesus ever think that maybe there was just a misinterpretation [sm=bangbang.gif]
Old 01-19-2008 | 08:34 AM
KarTuneMan's Avatar
Now, now boys.... I'm gonna send you both to your rooms if you can't play nicely.
Borrow a deck from one of your bud's (not another Pioneer) .... swap it out with the Pioneer, and watch the noise fly away.....
Old 01-19-2008 | 11:35 AM
oh snap i got grounded.... i promise i'll play nice from now on...lol
Juanjo_52
10-20-2014 05:45 AM
TiaMarie
09-14-2011 10:25 PM
Dipsetcivic117
04-03-2010 07:14 AM
enigma34
01-08-2009 08:02 PM
Bostonhoodhop
05-18-2007 03:13 PM
