DIY: Sidemarker Wiring
Background info:
Our corner lamps are dual filament bulbs which have 3 wires:
Red +12V parking lamp
Green +12V blinker
Black 0V ground
(colors may vary, check your manual or use a multimeter)
The sidemarker has a single filament, which has 2 wires:
Red +12V
Black 0v ground
How do you want it to be wired? There are 3 options...
Option 1:
-Sidemarker is illuminated (providing your parking lamps are on)
-Otherwise, sidemarker is off (it will not blink)
Option 2::
-Sidemarker and blinker blink in phase (at the same time)
Option 3:
-Sidemarker and blinker blink out of phase (alternate illumination)
-Otherwise, sidemarker is illuminated (providing your parking lamps are on)
How do you wire them up?
Option1-
Connect Red to Red.
Connect Black to Black.
Option2-
Connect Green to Red.
Option3-
Connect Red to Red.
Connect Green to Black.
The reason/how option 3 works…
When the parking lights are on, +12V is on the positive side of the sidemarker and the blinker, being off, sends no voltage (0V) to the negative side. This +12V illuminates the bulb. Now, when the blinker is activated, +12V pulses are observed on the negative side. This means that there is +12V on BOTH sides of the bulb, which because of the lack of voltage difference, the bulb turns off. This is also why the blinker and sidemarker alternate illumination.
Green +12V blinker
Black 0V ground
Red +12V
Black 0v ground
Option 1:
Option 2::
Option 3:
Option1-
Connect Red to Red.
Option2-
Option3-
Connect Red to Red.
