crackling noise help plz
Old 03-10-2008 | 07:14 PM
SHYTXNASTICK's Avatar
Default crackling noise help plz
okay ive had my alpine type rs in my 05 sedan for like 4 months max right now. I had recently (about a month ago) installed an alpine hu, type r sub and amp into my car. However, now when i play my music my right rear speaker has this annoying crackling sound to it. I need help plzz
Old 03-10-2008 | 07:53 PM
logand5's Avatar
Default RE: crackling noise help plz
It sounds like u havea bad conection probably just a loose wire from ur speaker to ur hu.
Old 03-10-2008 | 07:57 PM
civicduty96's Avatar
sounds like you poked your speaker already
Old 03-11-2008 | 06:09 AM
imshirazy's Avatar
You either blew your speakers, have a loose connection, or a wire is grounding itself
check all three, including RCA connection
also try hooking up another speaker to that port to see if it does the same, if it doesn't, then it's your speaker with the problem
Old 03-11-2008 | 09:15 AM
Temporarily swap the speaker wires at the amp from left to right. If the problem stays on the right side it is either the speaker itself or the speaker wiring. If it moves to the left it is going to be the amp, RCA cable, head unit, i.e. something before where you swapped the wires.
Old 03-12-2008 | 11:31 AM
ltkenbo's Avatar
That's really weird, I have a type R system (6.5's in front, 6x9's in back, 12" type r sub, and 2 type r amps and pioneer head unit) and my front right speaker makes a crackling noise as well. But only on certain songs, I might be having a similar problem to you. Weird huh.
Old 03-12-2008 | 03:01 PM
yeah haha that is really ironic. However thanks for the feedback..al there was was a loose wire and i tightened it up a bit and now it works good as gold! :-)
thanks again guys
Kersley
09-10-2013 04:38 AM
carrera
07-15-2013 07:28 PM
Questar
09-05-2012 10:31 PM
that_guy5
02-09-2007 09:09 AM
addiction2bass
07-21-2006 05:38 AM
