Cracking Speaker Help????
Old 03-27-2005 | 03:38 PM
Josh1122's Avatar
Default Cracking Speaker Help????
Hi
When i turn my sterio to 0 or all the way off the speaker makes a cracking sound then stops. It is not the speaker itself for sure. Also the wiring is done correct. What could it be???? Plz get back to me THX
Old 03-27-2005 | 03:47 PM
D16z6's Avatar
Default RE: Cracking Speaker Help????
does it sound like static sound??
Old 03-27-2005 | 04:44 PM
Nail I3unny's Avatar
are u sure the wiring is all ok? i mean, did u check every length of the wire?
if so then my only guess would be a bad signal
Old 03-27-2005 | 05:06 PM
Remmy's Avatar
Its called a 'thump' if you ever have read some specs on an amp its will say (on most newer amps) either "soft thump" or "soft start"
Old 03-27-2005 | 07:54 PM
Josh1122's Avatar
Hi you said sumthing about a bad signal for my speaker cracking what do you mean by that and how would i fix it?????
Thx josh
Old 03-28-2005 | 01:19 AM
Pete's Avatar
If this is a full range speaker then it sounds like your speaker has a loose wire, or maybe it is touching a ground when in place. Make sure u check the speakers terminals. Are these stock speakers and headunit?..........check the connection behing the head unit. For amplifiers you can use this device to eliminate that annoying amplifier POP turn on sound. (ive got 1 for my Rockford amp)
http://www.cardomain.com/item/STISPSON
Mechanixs02
07-24-2008 06:06 AM
cowsgonemadd3
02-20-2008 06:30 PM
Josh1122
03-29-2005 04:53 PM
Josh1122
03-29-2005 01:51 AM
FlyGLi
07-24-2004 10:22 AM
Quick Reply: Cracking Speaker Help????
