Burned two fuses...
#21
Okay now I got a cap into the equation, I know its supposed to go near the amps but should I put it on before the power block or after, and thereby only my amp for the subs would be getting the cap juice.
Also: I remeber reading a article when I first got into messing with my sound that the cap and amps should have their own ground but on the instructions for the cap it said to put the amps grounds into the caps negative and the caps negative would be a ground for the amps and the cap itself.
Which is the correct way?
NIKE H34D
09-02-2012 01:17 PM
