Amplifier question
Old 01-03-2008, 08:10 AM
imshirazy's Avatar
Default RE: Amplifier question
Ok but this is kind of contradicting
one an amplifier lets say rated
1000 @ 1 ohm
700 @ 2 ohm
500 @ 4 ohm
obviously going lower on ohms will affect the power output to the sub, so yes it does affect the performance of the sub
And they don't just make different coils for amplifier choices, but as well amount of sub setups
And subs wired to 1 ohm will not actually sound as clear as 2 ohm, something not many know
Less resistance for the amp also means less control
Old 01-03-2008, 07:46 PM
Littlehag's Avatar
ORIGINAL: imshirazy
1000 @ 1 ohm
700 @ 2 ohm
500 @ 4 ohm
you took the words right out of my mouth
Old 01-04-2008, 02:53 AM
Stumasters's Avatar
I don't know of any good solid brands that produce a 5 or 7 channel amp, personaly.
and +1 on the amp/ohm/coil comments.
Remember that your power output all depends on your setup.
Buying 2 2ohm subs doesn't mean it will run at 2 ohms, likewise buying 2 4 ohm subs doesn't mean it will run at 4. When you wire subs together the resistance can half, double, or quarter. It all depends on the wire up. So take into consideration exactly what setups you can choose from with a pair of speakers, then you can shop for an amp that will power them properly.
I have seen people 10000 times buy a pair of subs, buy a cool amp, only to find out that their subs will only run at 8 ohms, which on their nice little amp supplies about 75-100 watts to each speaker which were rated at like 400 watts. Talk about a ****ty situation.
Raul98
02-21-2006 03:26 PM
Pete
04-13-2005 11:40 PM
Josh1122
03-31-2005 09:59 PM
AgentofDarkness
02-18-2005 12:11 PM
ballplaya4eva07
12-18-2004 01:26 AM
Quick Reply: Amplifier question
