amplifier channel
RE: amplifier channel
technically, a channel isn't really how many speakers you can run.. because you can wire up many speakers to one channel. A channel is basically an individual signal. For example, a 2 channel sysstem (called stereo) has a left (channel 1) and right channel (channel 2). If i send sound to channel 1, only those speakers wired to channel 1 (left channel) will produce sound... this makes it possible to play one sound on the left side and one sound on the right side at the same time. If you only had 1 channel, you could not do this..
edit: also, when you hear DOLBY SURROUND SOUND... this is like 5 channels (i think).. the individual channels allow movies to play sounds on different speakers to give you the effect that some sounds are coming from behind you.. if you only had 1 channel, this would be impossible
what do the different channel amps mean? Im thinking of getting a head unit, amp, 2 subs, and four new speakers for my 97 ex. What kind of amp would i need?
i am going to hook the speakers and subs to the amp. Can i put the front two speaker on 1 channel, and the back two on another channel? Also can i hook up 2 subs to 1 channel, or would two channels be best? So im looking at a 3-4 channel amp right?
3 channel amps. I newer saw one but I am sure if you look hard enough you'll find one. As to connecting 2speakers to one channel not a good idea. What kind of set up do you want for your car. Do you want to be heard in 1/4 mile radius or just clean nice base that isn't to f*** loud and does't make your whole car rattle. Whell for a good set up you probably want to get nice head unit Alpine and Pioneer seems to be favorites on this cite, but Sony is good to. All four aftermarket speakers, I am going with pioneers and one 12" sub or two if you really want a good base, Sony Xplode worked for me. And an amp for the subs do some research on that. I woudn't connect speakers to an amp but that is you choice, but if you do go with small 4channel amp.
do i need a battery to power the amp or will i be fine with my car battery
i just want it to sound like good quality. I dont want to be heard 3 blocks away, but i want it to be loud enough. If i hook up 4 speakers to the head unit, will they still sound good. I'm thinking infinity speakers with sony or pioneer.
civic96lx
06-14-2007 07:38 PM
addiction2bass
01-16-2007 12:55 PM
