Amp question w/ already installed basslink
Hey guys I currently have the 200w infinity basslink installed, but I am now loookin to put in a simple 2channel amp for my front speakers. I just have a question about installation,
Do I just get an amp kit and run the power cables along with the already installed ones? is that fine for my battery?
As for an amp, anyone have experience with-
Profile
Lightning audio
pyramid
Thanks!
Profile
Lightning audio
pyramid
Thanks!
RE: Amp question w/ already installed basslink
Upon doing more research I could use a distribution block right? I am currently running 8 gauge wire and from what ive read that's good for up to a 60 rated fuse. My basslink uses a 20 and another amp would use 25. So I could still use the same wire???
I would say that it would be just fine that way...just keep in mind that if you ever wanna upgrade for more power you'll need a new power wire. But for what you are running I'd say go for the dist. block.
*Edit: Just make sure the fuse on the power wire up at the battery meets/exceeds the fuses at the other end...otherwise you'll be popping that fuse all day long.
