amp output
this is what it is.
http://www.lightningaudio.com/produc...s=discontinued
so how much power would my sub get if i turned the gain all the way up?
first off.... THE GAIN IS NOT A VOLUME CONTROL!!!!!!!! if you think it is youll either blow the subwoofer or blow the amplifier OR BLOW BOTH!
the amplifiers output depends on the subwoofer voice coil configuration and the way you wire it up if its dual voice coil.
Anyways, the amp is rated at 250 if you bridge the channels (which can only be done with a 4 ohm single voice coil sub or a 2 ohm dual voice coil sub). to find out how much it really puts out, you can have it bench tested.
