alternater
RE: alternater
I ran a 1500WRMS amp (on my sub) plus a 250 WRMS (on mids/highs) without too much "problems" other than lights dimming.. It is really all relative though. some amps are MUCH more efficient than others ( meaning, they will produce more power to your speakers while drawing less poser from your electrical system) I eventually burned out my alternator, and had it rebuilt a lot stronger ( stock was 60A, rebuilt to 114A) Anyways, its really tough to tell you what is the largest wattage amp you can put in your stock electrical system, There are many classes of amps, some much more efficient than others. (Class A, B, A/B, D, T.) Class T is one of the most efficient from what I understand, however, from what I hear, they lack "*****" meaning they are kinda on the weak side, compared to other amps at the same rated power (some amps will do well over their RMS rated power)
I hope this helps a little, if nothing else, I hope it helps you realize why you got no response before.
HD
HD
