Aiming headlights
To aim them, turn the screws on the back side of the headlight housings (two for each headlight... one adjusting left to right, one adjusting up and down).
Basically what you want to do is point them as high up as possible without blinding people.
I think the hot spot of the beam should be pointing a few degrees under straight out from the headlight. That way, you can see far in front of you, and at the same time not blind people.
Cosworth
12-15-2008 05:35 AM
AdamC
06-02-2004 04:08 PM
