93 honda civic DX radio
RE: 93 honda civic DX radio
1 take out the ashtray
2 remove the two bolts on each side of the lower console, the piece the ashtray is in, and then the two bolts facing upwards
3 make sure the shift lever is out of the way by moving it to 3rd gear, or 1 on an automatic. on the automatic, use the parking brake and put the key in the shift lock release and move the lever.
4 start to pull off the lower console part of the dash, reach behind, and unplug the 12V plugs wire harness
5 remove the lower console piece all the way
6 there is a bolt holding the stereo to the stereo frame, on the underside of the stereo, towards the back. remove this bolt
7 push the stereo out from behind, unplug the wire harness, and remove the antenna plug
WKD_DRGN
09-12-2010 04:28 PM
velvetmaggot
08-18-2010 06:02 AM
