91 sedan stereo wiring
So, here it is. I have two different decks, pioneer and sony. The install is in a 91 dx sedan. Ive found my constant hot,my acc, and proper grounding but niether unit will light up or nothin......wtf am I doing wrong? Any help on 4th gen wiring would be nice. thanx
Yes the constant +12 comes from the "BACK UP" fuse in the box near the battery under the hood. If you're cutting and splicing the car wires instead of using a harness adapter (not recommended), disconnect the battery before working on any wiring to avoid blowing fuses.
To test a deck take it out of the car and hook the red and yellow wires together to the (+) of a car battery, and the ground wire to (-). Make sure none of the speaker wires are touching each other or anything else. The deck should light up and act like it's playing.
needs more salt
07-11-2006 12:34 AM
