6 disc changer Q?
Old 03-14-2005 | 01:02 PM
oldschool's Avatar
Default 6 disc changer Q?
I have a stock tape player in my 98 LX 4dr. I want to keep the stock and add a 6 disc (or 10, whatever) in the trunk. Ive seen changers that are FM modular. I think this means you tune in to a preset channel, which is on the same freq. as a signal from the changer. Does this sound correct? Does the sound suck ***?
Has any one tried this set up?
I wouldn't mine wiring a regular (wired) changer from the trunk to the stock tape player. Any suggestions on a good changer? Does it simply wire into a stock deck?
Thanks
T
Old 03-14-2005 | 01:11 PM
StifflersMom's Avatar
Cat Fuсker
Default RE: 6 disc changer Q?
If you can find a used honda changer I think it will work right with the stock deck. I, being a wishful thinker tried fitting a non-honda changer do the stock deck...didn't work...
Old 03-14-2005 | 06:09 PM
Remmy's Avatar
an FM Modulator is only as good as your radio is. It wont be CD quality, either get a cd changer compaitble tape deck or live with the sound... thats about it unfortunatly.
Remmy recommends:
Tape Deck(s): http://www.eclipse-web.com/index_cassette.html
CD-Changer: http://www.eclipse-web.com/index_cassette.html
Old 03-15-2005 | 05:42 PM
oldschool's Avatar
thanks
I found a direct factory compatible Apline disc changer on Crutchfield.com for $220. I will most likely get it.
T
Old 03-15-2005 | 09:29 PM
NTX's Avatar
NTX
I used an alpine 6 disc with my stock player with no problems.
Old 03-15-2005 | 10:33 PM
Remmy's Avatar
huh, i completly forgot about that. Sorry I forgot to metion that... have fun
Old 03-17-2005 | 10:19 AM
Roost3r's Avatar
FM taps are a REALLY bad idea unless you plan on only driving within a 15 miles radius..
Old 03-20-2005 | 09:25 PM
D16z6's Avatar
Yep i would also recommend a cd changer compaitble tape deck. I have a sony tape player with a 12 disc changer and it work perfectly.
dblclutchin
11-20-2006 10:50 AM
honda808
06-21-2006 11:00 AM
carlosian
04-27-2006 04:28 PM
carlosian
04-12-2006 01:13 PM
civicprts4sale
11-18-2005 09:52 AM
Quick Reply: 6 disc changer Q?
