2 P2's for 150?
RE: 2 P2's for 150?
What would be a good amp to power them with? My friend said they are 800 RMS a piece so should i look for 1600 amp or less or more? Im looking for a fairly cheap one. What would be the least i could go with without damaging the subs?
Edit: How does this look? http://cgi.ebay.com/NEW-SONY-XM-D600...QQcmdZViewItem
RE: 2 P2's for 150?
Sony Xplod xmsd22x I would bridge each speaker with a amp.$120.00 times 2=$240.00
200 watts RMS x 2 @ 4 ohms
250 watts RMS x 2 @ 2 ohms
500 watts RMS x 1 bridged @ 4 ohms
variable low-pass filter (50-300 Hz at 12 dB per octave)
bass boost (10 dB @ 40 Hz)
Class A/B 2 channel bridgeable car amp
Tri-way capable
MOS-FET output stage and power supply
C--E--A-2006 compliant
preamp- and speaker-level inputs
preamp outputs
15-7/8"W x 2-1/4"H x 11"D
It has to be close to rms I looked up p2s and found all kinds of models.
Tri-way capable
preamp outputs
RE: 2 P2's for 150?
no i dont see a vin or anything on the subs. I cant find any p2's that ARE 800 watt rms. I wonder what it could be?
edit: i just called him to make sure and he is convinced they are 800 rms a piece and he ran a 1600 kenwood amp to them.
