2 channel amp powering 4 speakers?
Possibly.
According to the specs on that amp, it's stable at 2 ohms giving you 125x2. You will want to make sure your speakers are good to run at 2 ohms and then you'll have to wire them as such. This probably means running new wires to all 4 speakers. Are your 6.5s and 6x9s single voice coil or dial voice coil? (Some of mine used to be, thats why I ask.) I'll assume single voice coil, 4 ohm.
You'll want to wire each side basically like this:
Image borrowed from the12volt.com
yes you can use that amp and those speakers but wire both of the lefts together and both the rights together
the speakers ohms don't change
not necessarily but I deff would if you are running 75 watts rms to each
ive never heard of dial voice coils ha ha and ive never heard of dual voice coil speakers just subs
what brand,model numbers?
Sometimes I get retarded when I haven't slept in two days.
True, but if you run them wired to a total resistance of like 1 or 2 ohms, they get more power which could blow them if their RMS rating is low.
Of course I meant dual. Typos happen. Yay for proofreading.
Kenwood kfc-somethings. I've still got them somewhere. If I dig them up I'll let you know.
makes sense
cool, I was just makin sure you were not one of those walmart xplod ricer types
91_CIVIC_ZC
07-30-2006 03:53 PM
