07 Civic 4dr. amp install question
I know this may be a stupid question, but has anyone put an amp and subs in a new civic. If so, where did you run the power wire for the amp through the firewall. I have been under the dash and under the hood and cannot find any thing to run it through. PLEASE HELP!!!
RE: 07 Civic 4dr. amp install question
im pretty sure under the passenger side front wheel well if u take off the coupel clips or scres holding on the black plastic covering thing theres a rubber thing in a hole in there...takea screwdriver and poke a hole through that and push the wire thoruhg make sure the wire is tight inside it tho so water cna't get through
for AUTOMATICS- there is a small 4 gauge knock out panel on the driver side firewall where the clutch would go if it had one or its also located to the top right of the break booster .
for STANDERDS- between the brake booster and front driver side strut tower
civic96lx
01-17-2009 09:22 AM
