engine swap
Old Apr 24, 2010 | 03:56 PM
F91civic's Avatar
Default engine swap
what is the best sohc swap to run a turbo kit? going to run a t3/t4 hybird turbo kit not sure if i should run sohc non-vtec or sohc vtec? any help will be greatful.
Old Apr 24, 2010 | 08:03 PM
the d16z6 is a real good motor, its a vtec motor from the 92-95 civic ex or si.
Old Apr 25, 2010 | 03:21 PM
F91civic's Avatar
thanks i was thinking about putting a vtec engine in the car. but i thought it would be to high of a comp ratio.
Old Apr 25, 2010 | 03:36 PM
thats why you can just get a thick head gasket and it will help lower the compression ratio, also you can change the pistons to help lower the compression ratio.
the d16z6 is a really good motor and will handle boost
chbulldogs11@msn.com
May 27, 2011 09:05 PM
skibum853
Nov 18, 2007 09:40 AM
badboy4life
Sep 1, 2007 08:28 AM
Kingzlei
May 5, 2007 04:06 AM
silvr63vet
Dec 4, 2006 03:55 PM
