2 New Tires
Old Nov 20, 2009 | 09:58 AM
b.line's Avatar
Default 2 New Tires
Hello Again,
I'm finally getting around to replacing 2 of the tires on my Civic.
I'm replacing with the original tire size but changing manufacturer.
Should I put the new tires on the front or back?
I'll probably be driving like this for a few weeks til I can get the other two.
Thanks in advance.
b.line
Old Nov 20, 2009 | 10:00 AM
DaOne's Avatar
the new tires always go on the front if your only replacing two of them...
or at least thats wat the tire place told me lol
Old Nov 20, 2009 | 10:11 AM
b.line's Avatar
Default Agreement
That's what i would have thought...
but there is a sign on the wall in WalMart that states the opposite.
I would think the back tires would almost be a non-issue as long as they are in pretty good shape.
Maybe that's for rear wheel drive cars.
Thanks,
b.line
Old Nov 20, 2009 | 10:16 AM
i would just go ahead and replace all four tires with the same brand, i always thought the better tires go in the back
Old Nov 20, 2009 | 10:18 AM
b.line's Avatar
Default additional info
I'm replacing with the Bridgestone Turanzas Serenity series
205 x 55 x 16 91H
Old Nov 20, 2009 | 10:22 AM
here check out this video, that should convince you
http://www.michelinman.com/tire-care...artire-change/
Old Nov 20, 2009 | 10:36 AM
DaOne's Avatar
Yeah then put new ones in the back.
haha good thing i got all four.
Old Nov 20, 2009 | 02:35 PM
... yeah. Video or not, I'm still going to put the best tires on the drive wheels, especially when said wheels are also steering the car. Besides, I can recover from an oversteer condition no problem. Understeer... what can you do other than reduce speed and pray for the best?
And before anyone says something ignorant, I've experienced both under- and oversteer (as well as hydroplaning) on both front- and rear-wheel drive cars.
Also, I'm just going to point out that you really shouldn't even be going 45 around a turn if there's standing water on the road.
*edit: also, with the whole "best tires always in the rear" thing... like I said, best tires on the drive wheels. I have a mustang. I have brand-new tires in the rear and tires with about 4/32" tread depth in front. I understeer like a **** around relatively tight turns at anything faster than 20... happens almost every time I try to turn left at the intersection leading to my apartment. I'd rather lose traction and be able to steer than lose both traction and steering (same intersection scenario with a fwd car). The only reason I haven't bounced off the curb on the side of the road at the intersection is because it happens so often that I prepare for it before it actually happens... and, well... induced oversteer
Old Nov 21, 2009 | 09:17 AM
b.line's Avatar
Default Thanks to all
OK gentlemen,
We have batted this around enough...to each his own.
It's only til my next paycheck.
I appreciate the replies.
b.line
soafed
Nov 25, 2008 01:17 PM
remy
Aug 15, 2008 08:13 AM
natecivic92
Jun 4, 2007 07:00 PM
kikaSI
Nov 13, 2006 11:52 PM
bloohatch
Jul 23, 2005 10:05 PM
