Running Rich
Old Nov 11, 2009 | 02:47 PM
eggs90's Avatar
Default Running Rich
Need help... 1990 hond civic 1.6 dx has been running rich since I bought it..
it is just my to work and back car but I would really like to get it running properly being as work does not pay for gas... I have tried everything I can think of replacing: 02 sensor, IAT sensor, IAC valve, catalytic converter,Checked the timing, fuel filter, distributor, air filter.. I believe there is a problem with my duel point injection but am not familiar with it... is there and easy way to test this or fuel pressure regulator????
Old Nov 11, 2009 | 03:15 PM
well one injector is constant spray for idle and the other injector is for throttle
are your spark plugs gapped correctly? what spark plugs do you have?
have you check the coil and see if its giving a strong blue spark?
Old Nov 11, 2009 | 04:12 PM
eggs90's Avatar
yes... I just replaced the distributor... sorry forgot to mention that..and plugs and they are gapped correctly.. but I am running out of ideas>
Old Nov 11, 2009 | 04:13 PM
eggs90's Avatar
also think they are ngk spark plugs
Old Nov 11, 2009 | 04:36 PM
it doesnt matter if the dizzy is new they still can be bad, its best to check them,
its always better to be safe than sorry.
Old Nov 11, 2009 | 08:24 PM
eggs90's Avatar
ok... so I will check it in the morning. and let you know.. thank you for your help.
Old Nov 15, 2009 | 05:32 PM
eggs90's Avatar
update..... Checked spark plug and gaps all in specs. also getting strong blue spark and had the coil tested .. tested ok... also seems like the air box is sucking alot more air in than usual.....?????
Old Nov 15, 2009 | 10:36 PM
do you have any cel? pull the carpet up on the passenger side and look at the ecu, count the blinking light each fast blink =1 and each long blink =10 there may be more than one code, count til you are sure, and til it repeats itself
Old Nov 19, 2009 | 10:09 PM
eggs90's Avatar
update....pulled up carpet and no codes found???????what is the next step?
Old Nov 20, 2009 | 02:40 AM
get a timing light and check the timing, you may need to jump the ecu and adj the dizzy to get the timing perfect.
