Engine life.
Old Nov 11, 2009 | 07:08 AM
92civc4dr's Avatar
Default Engine life.
Will blocking of the idle air control valve shorten the life of my engine. Idle's fine drives fine got rid of sputtering before car would eat gas idle would repeat up to 3000rpms drop. Dont have a enough cashflow right now to buy a new one.
Old Nov 11, 2009 | 07:33 AM
usually cleaning it fixes it,
Old Nov 11, 2009 | 08:46 AM
92civc4dr's Avatar
Ive done that but didnt hear a difference plus it would spit out gas every time it would rev down.
Old Nov 11, 2009 | 09:14 AM
any cel? does the cel work?
whats spitting out gas? because the injectors are all pointing down into the cylinders
Old Nov 11, 2009 | 11:22 AM
92civc4dr's Avatar
sorry gas would come out of the exhaust. cel?
Old Nov 11, 2009 | 12:55 PM
cel = check engine light.
if gas is coming outta the exhaust that means it isnt burning it and you need to check your spark,
Old Nov 11, 2009 | 05:34 PM
First, get the CEL working (it should turn on for 2 seconds every time you turn the key on but don't start) and then use it to check for any ECU trouble codes.
Old Nov 19, 2009 | 02:35 PM
lilytek's Avatar
not really in my opinion, but your fuel consumption on your car might go down the drain, pretty easy to take off and clean by yourself, it's not in the most difficult place to access.
Old Nov 19, 2009 | 09:15 PM
Lewy2k's Avatar
Clean your FITV also and readjust it too. Has your motor been timed properly?
Old Nov 21, 2009 | 01:45 PM
lilytek's Avatar
Also too while it may not damage the engine, if your car is running too rich you run the risk of ruining your catalytic converter, which down the line will cuase problems with your engine (i know, had a cat blow out and caused too much backpressure made driving the car a nightmare)
Katmandu
Jun 15, 2008 04:47 PM
baiwldrnner
Mar 17, 2006 11:06 AM
royb86
21
Nov 28, 2005 04:25 AM
ghetto ryde
Jun 11, 2004 03:33 PM
