Fog Light Bulbs?
Old Nov 8, 2009 | 08:41 AM
KingDakota12's Avatar
Default Fog Light Bulbs?
I have the aftermarket ebay fogs and my one on the left blew out and got water in it after a car wash. So first just wondering what size the bulb was an H3 and should i use clear silicon to seal it after i replace it? And also I found an H3 bulb at Pep Boys, but it was small, what do they look like?
Thanks!
Old Nov 8, 2009 | 01:04 PM
yup h3, i guess it doesnt hurt to seal them up with clear silicone
they look like this
Old Nov 8, 2009 | 01:12 PM
Dipsetcivic117's Avatar
are all civic fog lights this size bulb? i plan on getting some fog lights for my eg. and was going to upgrade the bulb.
Old Nov 8, 2009 | 01:52 PM
If you get OEM or OEM-replica foglights then it is likely they will use an H3. You should check first of course though.
Old Nov 8, 2009 | 03:23 PM
most foglights i had experienced with use H3, so there is a high chance that your foglights uses H3 as well
Old Nov 25, 2009 | 03:08 PM
Lewy2k's Avatar
I have the OEM style and just had to replace mine. You will notice that upgrading to a cheap pair from the auto parts store makes a huge difference then the ones that come with the fog lights.
Old Nov 25, 2009 | 08:11 PM
Tiran's Avatar
Yeah, my JDM Fog lights (legit, check my thread) are H3s as well.
If you want your fog lights to work REALLY well, I suggest upgrading to a name brand, you actually do get what you pay for.
Personally I use Raybrig bulbs, and now just the fog lights are as bright as my stock headlights were.
I know eautoworks.com carries them, that is where I got mine.
And yes, drain the housing thoroughly, dry it real good, and then seal it.
Old Nov 25, 2009 | 11:53 PM
croninc's Avatar
yes they should fit, i had to cut this little piece of metal off the side of the replacement bulb, but other than that it was simple. Also recommend silicon!!!
Old Nov 26, 2009 | 07:03 AM
hey tiran...can we see a picture of the fog lights and the new bulbs.
Old Nov 26, 2009 | 07:04 PM
Tiran's Avatar
last post of my project thread
https://www.hondacivicforum.com/foru...6&postcount=28
Those are the same bulbs I have in my headlights, Raybrig Metal Thunder 4700K 12v. they are 55w but perform like 95w (somehow)
Like I said, I never used my stock bulbs, upgraded right away.
