Need Help!?!
Old Nov 1, 2009 | 05:20 PM
Jwpohl's Avatar
Default Need Help!?!
I have A 88 honda civic hatchback I have a code coming from the ecu trouble code 8 which is the tdc postion how can I fix this problem any ideas??
Old Nov 1, 2009 | 07:50 PM
open your dizzy and check the rotor and the screw make sure its tight,
Old Nov 2, 2009 | 02:12 AM
Jwpohl's Avatar
new rotor and new cap along with wires and plugs
Old Nov 2, 2009 | 06:51 AM
i dont care if its new, i said to open it and look inside thats why ur getting the code, u may not have tightend the rotor screw enough and it backed out, if not then u may have a bad tdc sensor.
Old Nov 2, 2009 | 05:25 PM
Jwpohl's Avatar
so if thats the case then I have to replace the whole assembly??
Old Nov 2, 2009 | 06:02 PM
yea or find a used one
Old Nov 2, 2009 | 10:25 PM
Jwpohl's Avatar
I got one off a d16z6 will that one work?? i was going to do a conversion but i desided to do a b series swap instead
TunerShark
Sep 23, 2006 05:27 PM
rx9790
Nov 1, 2005 05:53 PM
Jas10hon
Jul 4, 2005 10:35 PM
CivicCrazy
Nov 29, 2004 11:50 AM
