inside clock stopped working.
Old Oct 28, 2009 | 04:19 PM
DjHagios's Avatar
Default inside clock stopped working.
my inside interior clock in my 93 civic doesnt work. ive checked all the fuses and still nothing. it makes my radio not work either. the memory on my radio and clock have stop working.
Old Oct 28, 2009 | 06:14 PM
croninc's Avatar
sorry im unfamiliar with the interior of the 93 civics. Is the clock seperate from the radio? Im just curious because the same thing happened to my friends integra when some stole his aftermarket radio and wen we installed the stock one nothing worked, if the clock and radio are seperate you might have had the same problem as him.
Old Oct 29, 2009 | 05:13 AM
the constant 12v radio wire, and the clock wire all run on same power, look under the hood at the fuses thats where the power comes from.
Old Nov 6, 2009 | 06:47 PM
DjHagios's Avatar
i mean it cant be the inside fuses cause my radio and cigarette wouldnt work either but they work fine. but ill check under the hood for fuses.
Old Nov 13, 2009 | 04:29 PM
DjHagios's Avatar
update it was a fuse in side my engine bay. my clock started to work agian, my heat works now and my radio's memory is back. thanks for the help.
Obcanska
Aug 24, 2013 09:03 AM
stick only
Jan 4, 2006 09:05 PM
farkus
Nov 24, 2005 08:46 PM
cfauvel
Sep 22, 2005 01:23 PM
Forty04
Jul 11, 2005 08:24 AM
