Ground wires
Old Oct 16, 2009 | 10:27 AM
MaximusFunk's Avatar
Default Ground wires
My ground wires look pretty corroded, I want to put in new ones for both battery and engine. Is there a specific material or thickness that I should buy at the hardware store? would I be saving much money making them myself?
Old Oct 16, 2009 | 11:31 AM
you can clean them with a can of coke a cola. seriously
Old Oct 16, 2009 | 11:52 AM
supersize's Avatar
Sir Banned-a-lot
coke fizzes up, u can use it to clean alot of things, just make sure u wipe the coke off once its clean so its not sticky and wha-la! im suprised you dont see that on those infomercials
Hi, billy mays here with coka-a-clean! 1 can of coke and your **** will be mad chean, thats how they do it in japan yo'
Old Oct 16, 2009 | 11:57 AM
cool, should I soak them in it or just scrub with it?
Old Oct 16, 2009 | 03:33 PM
notnormal's Avatar
You can clean then with a wire brush also. Clean the parts that contact each other. Make them look shinny and new. Be sure to apply some dielerictric grease between the 2 connectors before you bolt them back together to keep them from corroding again.
Old Oct 16, 2009 | 05:48 PM
Sigracer10's Avatar
just go get some 4 gauge copper wire and make some new ones. and make a new transmission ground and upgrade your alternator power wire at the same time
just go get some amplifier power wire from any car audio store. Custom shops will probably be a better source because a lot of them will sell it by the foot.
and get some of these for the ends.
http://www.rockfordfosgate.com/produ.../RFTSx_1_l.jpg
Old Oct 16, 2009 | 10:31 PM
supersize's Avatar
Sir Banned-a-lot
just get a wash rag and plase it under the wire and dump the coke on the wire so itll go on the wire and drip on the rag.. no mess!
Old Nov 8, 2009 | 03:58 AM
EKSiR99's Avatar
i used gauge 4 stranded wires for my grounding
Old Nov 8, 2009 | 06:36 AM
Superfly's Avatar
You can clean it with coke, or just buy new wire. Really it's up to you.
If you go the new wire route, go here:
http://knukonceptz.com/
Old Nov 9, 2009 | 07:30 AM
If there is a car audio store in my town I cant find it. I tried lowes, autozone, and walmart to no avail so I just bought a grounding kit instead.
However, the rubber boot on the +alternator terminal wont fit snug over my new wire, is there any reason I cant leave it off?
