civic periodicly stumbles
Old Sep 26, 2009 | 07:15 PM
kootenay kid's Avatar
Default civic periodicly stumbles
Hi all new here, I have a 1999 civic SIR with 227,000km on it. Just yesterday while driving the car normally, the car lost power badly and the check engine light started flashing. This lasted a very short time and cleared up. I have had this happen 4 times now and I have had it connected to 2 different computers but they cant find a fault code. Today we changed the spark plugs because they hadnt been done in awhile.
Any suggestions?
Old Sep 26, 2009 | 07:20 PM
when the cel flashes like that it means a misfire, i suggest doing a full tune up, change plug wires, distributor cap, rotor, fuel filter, air filter.
Old Sep 29, 2009 | 04:21 PM
Well, after 400 bucks to do the full tune up, guess what? The problem is still there. We cannot find any fault codes whatsoever on the computer. Is it possible there is a problem with the v tech engine management system? Any other ideas?
Old Sep 29, 2009 | 04:38 PM
Have you check the timing on it?
Old Sep 29, 2009 | 05:31 PM
Anytime the CEL has come on there will be a code stored. If the ECU is not getting it's backup power (which I think comes from a fuse under the hood), it will forget all codes every time you turn the key off.
Old Sep 29, 2009 | 07:10 PM
Would the diagnosis equipment at a Honda dealer pick up anything a private shops wouldn't? Is there any propriatery info only Honda can pick up on?
Old Sep 29, 2009 | 07:36 PM
when the cel comes on dont turn car off leav it runung and get codes pulled. so you can find out which cylinder is giving the problem then we can go from there.
Old Sep 29, 2009 | 09:50 PM
EJ8_Man's Avatar
A private shop should be able to tell you the same thing Honda does. I'm sure Honda has their own proprietary programs they use, but your computer was designed so that any shop with an OBD2 reader can plug in and check your codes.
The most common events that lead to misfire:
1) loss of spark
2) the air/fuel mixture is too far out of balance to ignite
3) loss of compression
Your ignition coil could be going out, but you would experience problems on all the cylinders. You'd need a shop with a ignition scope or a digital storage oscilloscope (DSO) to measure the firing voltage.
You could have a bad fuel injector, or a bad connection to your injectors causing a lean fuel mixture
Loss of compression is the worst case, you could have a burned exhaust valve or a faulty head gasket. Check your compression.
Does the car start smoothly or is it a rough start?
Old Oct 1, 2009 | 02:41 PM
The car starts and runs absolutely normally with the only exception being when it loses power for short periods of time. The CEL flashes only while this is happening, and when plugged to the computer (2 different shops now) there are no fault codes stored.
I have heard of certain model years, not confirmed which years, that have defective distributors. Anyone heard of this?
Old Oct 21, 2009 | 04:56 AM
troutman's Avatar
Default Any luck? I have same issue.
Have you found the problem with your civic?I am having the same issue with mine.I replaced the distributor(used)and still have the problem.Could be they're both bad but I'm curious if you resolved your problem.
