Need help on gsr swap!!!!!!!!!!!!!!!!!!!!!!!!
Old Sep 12, 2009 | 01:02 PM
hydro_yang's Avatar
Question Need help on gsr swap!!!!!!!!!!!!!!!!!!!!!!!!
i got a 1990 honda civic dx hb, and just got my 98 gsr motor back from the shop and now i need help on what tranny i should use (which i want to keep my cable clutch)and how i go about connecting the engine harness....
thanks
hydro
Old Sep 12, 2009 | 01:35 PM
first you have dual point right? you will need to rewire the ecu to covert your car's wiring from 2 fuel injectors(stock on dx) to 4 fuel injectors(mpfi)
Old Jun 4, 2010 | 07:52 PM
civtec00's Avatar
are you keeping it obd0? if so you need obd0 injectors, 90-91 integra injectors will work, make it multi port, run the vtec wires, use a pr3, or pw0 computer(if you are staying
obd0). any b series cable tranny will work just get the clutch for the tranny you use.
(90-91 b series is different than 92-93).
Old Jun 15, 2010 | 09:44 AM
finalimpact's Avatar
correct. 90-91 is a small spline set up and 92-93 are larger. if you happen to go with a hydro trans you can use the 92-01 clutches. i would highly recommend going obd1 if its withing budget. it will give you more options for tuning.
hydro_yang
Sep 12, 2009 01:18 PM
b18c_eg
15
Jul 22, 2008 07:53 PM
johnny
May 13, 2007 07:23 PM
djmatix
Oct 13, 2005 10:19 PM
