Identifying Your ECU
Old May 7, 2009 | 05:07 PM
Default Identifying Your ECU
Identifying your ECU
To identify your ECU you will need to know its generation, part number and possibly its ROM number.
The ECU can be located in several places:
  • under a metal plate in the passenger's footwell (88-91 Civics)
  • in the passenger's footwell behind the carpet (92-95 Civics)
  • in the passenger's footwell behind a plastic panel (96-00 Civics)
  • by the driver's footwell under a plastic panel (some 2001+ Civics)
The computer is connected via three connectors that pull out when a plastic clip is pressed. Remove the computer, and with a philips screwdriver remove the metal lid from the top of the computer. There may be small daughter circuit board covering some of the main circuitry. Unscrew this and lift it out of the way.
ECU Generations
Honda ECUs run in generations, which use different connectors. Below is a stack of ECUs running from the newest generation at the top to the oldest generation at the bottom.
  • OBD0 - 88-91 Civics
  • OBD1 - 92-95 Civics
  • OBD2a - 96-98 Civics
  • OBD2b - 99+ Civics
ECU Part Numbers
All Honda ECUs have a part number which is located on the side of the ECU and inside the ECU on the connector. e.g. 37820-P72-A01.
The format is always the same: 37820-XXX-XXX
The part number consists of three components:
  • Honda's part number for ECU, which is always 37820
  • Three characters (which are loosely related to the model of car/engine). e.g P72
  • Three characters (which are the revision of the ECU) e.g. A01 or G52
The middle 3 characters are the most useful to identify what the ECU is. Different generation ECUs may use the same characters. e.g. a P72 OBD I ECU is different from a P72 OBD II ECU. Here is a list of common ECUs:
  • PG7 : 86-89 Integra (86-87 vac advance, 88-89 electronic advance)
  • PM5 : 88-91 Civic/CRX DX
  • PM6 : 88-91 Civic/CRX SOHC Si
  • PM7 : 89-91 DOHC ZC (JDM 'EF' ECU)
  • PM8 : 88-91 CRX HF
  • PR2 : 89-91 ZC (Euro)
  • PR3 : 89-91 JDM B16A EF8/9
  • PR3 -J00 or J51 : 92 JDM Integra B16A EF8/9
  • PW0 : 89-91 JDM B16A EF8/9 DA6-XSi
  • PR4 : 90-91 Integra LS/GS
  • PS9 : 88-91 4 door Civic EX Auto
  • P05 : 92-95 OBD-1 Civic CX
  • P06 : 92-95 OBD-1 Civic DX
  • P07 : 92-95 OBD-1 Civic VX
  • P08 : 92-95 OBD-1 Civic D15 JDM
  • P0A : 94-95 OBD-1 Accord EX
  • P13 : 93-95 OBD-1 Prelude Vtec
  • P14 : 93-95 OBD-1 Prelude Si (non Vtec)
  • P27 : 92-95 OBD-1 EG JDM Civic 1600 sohc
  • P28 : 92-95 OBD-1 Civic Si/Ex
  • P30 : 92-95 OBD-1 DelSol DOHC Vtec Si/EG SiR
  • P54-G31 : 1997 Honda Accord 1.8 LS
  • P61 : 92-93 OBD-1 Integra GSR
  • P72 : 94-95 OBD-1 Integra GSR
  • P72 : 96-00 OBD-2 Integra GSR
  • P73 : 96-00 OBD-2 Integra Type-R (JDM & USDM)
  • P74/75: 92-95 OBD-1 Integra LS/GS
  • P75 : 96-00 OBD-2 Integra LS/GS
  • P2N : 96+ OBD-2 Civic HX Coupe
  • P2P : 96+ OBD-2 Civic EX Coupe
  • P2E : 96+ OBD-2 Civic DX Coupe
  • P2M : 96+ OBD-2 NZ Civic SOHC VTEC
  • P2T : 99+ OBD-? Civic Si Coupe
  • P5P : 97-00 OBD-2 Prelude Type-S (JDM ECU)
  • PBA : 97+ US Acura 1.6EL
  • PCT : 98+ JDM ITR / CTR
  • PCX : 99+ OBD-? S2000
The last 3 characters are broken down into 3 parts:
  • 1st Letter: country of orgin
    • J: Japan
    • C: Canada
    • A: USA
  • 2nd Digit: If this digit is 5, 7, or 9, then the ECU is for automatic transmission usually
  • 3rd Digit: denotes the version/variation
  • 88-91 ECU:
    • Manual: 000, 001, 002, A00, A01, A10, J00, J001, C01, C00
    • Automatic: J51, J50, A50, A51, 901, A60, C50, C51, X30, A80
  • 92-95 ECU:
    • Manual: 000, 001, 002, 003, A00, A01, A02, C00, C01, C02, J00, J01, J02
    • Automatic: J50, J51, 901, 902, C50, C51, C52, A50, A51, A52
  • 96-00 ECU:
    • Manual: 000, 001, 002, 003, A00, A01, A03, C00, C01, C02, C03, J00, J01, J02, A11, C11
    • Automatic: A70, A71, A72, A91, A92, C70, C71, C72, C91, C92
ECU ROM Numbers
As further identification Honda ECUs have a software revision number inside the ECU. This is usually a two or three digit number stamped on the 28 pin ROM, or main processor. Accord and Prelude ECUs can use a letter and number code.
Most of this information was borrowed from Hondata and PGMFI.org.
Marty
Dec 27, 2009 01:04 PM
jbum
Jul 10, 2007 07:36 AM
Japles
Dec 18, 2006 08:47 PM
