Old Apr 20, 2008 | 06:59 PM
danomatic93's Avatar
June 2010 ROTM
Default Danomatic's Update Thread: Modifying the EJ1
Updates are NOT on first page... ...Check the last page.
Links to my other projects for this car:
Drum-to-Disc Brake Conversion - https://www.hondacivicforum.com/foru...ad.php?t=53722
Interior Overhaul - https://www.hondacivicforum.com/foru...ad.php?t=48035
Sorry, I couldn't find a link to my original build thread, I think it got lost in the internets somewhere.
So, Instead of creating a new thread for every stupid thing I do, I'm making this one so that I can just update it accordingly.
Written end of Winter 2008:
In the last month or so ...
Lip is to be paint matched along with a type-r rear lip to match.
I installed the HOP console in and the Cup holder/Coin tray.
I finally got my diagnostic gauges in (Volts, Oil Pressure, A/F aka Light Show)
My pretty Honda floor mats
I also picked up a set of seats from a 98 Integra from traitorzxiong. Lumbar Support!!!!
So, today I got around to putting the coilovers, camber kit, and KYB AGX shocks on the front finally.
Also, while I had the wheels off, I screwed on the EK mud guards. That I picked up the the good ol' junk yard last weekend.
I don't have pictures of the whole car since I'm letting the springs settle before I drop her lower. I feel a slight difference over bumps, but I attribute that to the new shocks. I was using the stock Honda shocks with a cheap lowering kit before.
Here are two of the old coilovers (repainted to black, of course)
The fenders that I'm fixing up look will look like these (X1 Style):
I'm not going to put them on my car. I just bought them "cheap" because some guy didn't want to do the fiberglass work to fix them. I plan to fix 'em and sell 'em.
Here's my TO-DO list for this season (Spring 2008):
- A-pillar Gauges (oil press, voltage, A/F aka light show) DONE
- Skunk2 front camber kit DONE
- H.O.P. Center Conosle DONE
- Interior mounted antenna (I have no reception after I deleted my stock antenna, oops) DONE
- Skunk2 Coilovers DONE
- Replace front shocks to KYB AGXs DONE
- Convert an Auto ECU to Manual then chip it DONE
- Lips (Mugen front DONE, Type R rear)
- MORE Anti-theft measures DONE
- Skunk2 LCAs DONE
- Beaks Subframe reinforcement kit DONE
- 22mm ITR rear sway bar (and end links, bushings, collars) DONE
- Sidemarkers DONE
- Twin-loop muffler DONE
- Rear camber kit DONE
- Fender fix-up (Fiberglass X-1 style, I got them dirt cheap)
- Fuel Filter DONE
- Reupholster (the padding at least) my armrest. DONE
- Blox Rear Toe Adjusters DONE
Here's my TO-DO list for this season (Spring 2009):
- Parking Pole
- Polish my fuel rail
- mini wire tuck
- Fancy PWJDM washers
- Rising sun valve cover
- Front tow hook
- hood dampers again
My DIYs:
94-01 Integra Cluster into 92-95 Civic
https://www.hondacivicforum.com/foru...ad.php?t=71092
EG "Headlights On" Warning Chime
https://www.hondacivicforum.com/foru...ad.php?t=64300
EG Cluster and Dash Lighting Modifications
https://www.hondacivicforum.com/foru...ad.php?t=70378
Sidemarker Wiring
https://www.hondacivicforum.com/foru...ad.php?t=73597
Coilover sleeves
https://www.hondacivicforum.com/foru...ad.php?t=63294
Combination Switch Fix (Headlight Switch)
https://www.hondacivicforum.com/foru...ad.php?t=74275
DIY Parking Pole on LHD Civic
https://www.hondacivicforum.com/foru...ad.php?t=74304
DIY: DC2 Map Light into EG w/Moon Roof
https://www.hondacivicforum.com/foru...ad.php?t=76489
DIY: EG Dash Trim Piece Removal and Replacement
https://www.hondacivicforum.com/foru...161#post673161
Old Apr 20, 2008 | 07:32 PM
Default RE: Danomatic's Update Thread: Modifying the EJ1
looks good tho.... IMO.... id change the blue calipers to red to match
Old Apr 20, 2008 | 07:50 PM
June 2010 ROTM
Yeah, they do need to be painted already. This winter was hell on my car. The colors I'm considering are red, grey(gunmetal), and black. My car's color scheme is slowly but surely going towards black/white with misc. red which can be found in the suspension components and all the ES bushings. So... if my suspension parts are red, then I'll have to make the calipers black or grey.
Old Apr 20, 2008 | 07:57 PM
o ok.... id vote black calipers than..... they look great on my 99...
i painted alot of my suspension black with the caliper brush on paint... wire brushed the rotors outter lip also and painted black as well as the mounting hub and suck brackets. helps keep the rust look down... just as long as theres not rust on where the brake pads touch its great.....
just a few little touches. tho i painted my spindle arm with the spray paint caliper paint and it SUCKED!!!!!!!! so when i swap on my ground controls and new struts im gonna redue them with the brush on caliper paint! only thing that spray paint stuff was good for was the rear drums!
Old Apr 21, 2008 | 12:50 PM
Here's an idea for ya:
instead of fixing up the fenders and selling them, how about fixing them up, shaving the vents, and putting them on your car as stock-style fiberglass fenders? They wouldn't dent, and you'd still be saving around 4lbs on the front end.
and +1 on the black calipers... they're nice and subtle.
Old Apr 21, 2008 | 11:50 PM
June 2010 ROTM
So, I picked up an Auto P28 not too long ago and I finally got around to converting it and doing something else...
As you can see:
-28 pin DIP socket
-20 pin IC chip: 74HC373
-Jumper in position J1
-1k ohm resistor in position R54
-0.1uF capacitors in positions C51 & C52
-Datalogging pins in position CN2
-RP17 and RP18 components removed and RP18 jumped
Also, removed some other Auto components IC15 & IC16 for weight reduction, j/k.
Here's my pretty soldering job...
And here's with the ROM in place...
Why did I chip a different ECU and not my own? Because, I could not find out whether or not chipping my ECU would allow me to pass emissions or not. I'm just covering my butt.
Old Apr 22, 2008 | 01:33 AM
ya its a good idea..... once you find out your job works then you can think about selling your old computer. or just keep it JUST INCASE.
Old Apr 24, 2008 | 10:40 AM
June 2010 ROTM
Just got my Beaks Subframe reinforcement kit with 22mm ITR rear sway bar (and end links, bushings, collars) in the mail today!! Maybe I'll get around to it this weekend!
Old Apr 27, 2008 | 07:43 PM
June 2010 ROTM
I had a little fun with Seafoam today...
(sorry for the crap cell phone quality)
Old Apr 28, 2008 | 01:35 PM
THAT SUCKED.... come on couldnt ya at least give the phone to your friend to tape.LMFAO
hell i just went thru my pictures and found my seafoam of my 94... I SWEAR TO GOD you can kinda see the smoke rings i was blowing!!!!! it was funny as hell when i was doing it but the camera was kinda far away.. but you can kinda see the smoke ring if i played with the gas pedal JUST RIGHT!!!!!! i gotta edit that video to fit because its to large right now to upload
