Halo Headlights & Auxiliary Switch
Old Mar 2, 2008 | 08:33 PM
Default Halo Headlights & Auxiliary Switch
By: jpnolan
This is to hook up your halo headlights up so you have a separate switch. The idea is so you can have your halos on without your main headlights.
READ over the entire instructions before proceeding. I am not responsible if anything goes wrong, this is just how I did it.
Things needed: (*= not necessary but recommended)
Matching gauge wire to the wire coming out of your headlights,
A switch,
Wire strippers and cutters,
Wire connectors,
*electrical tape
Wire connectors with an O shaped end,
*Heat shrink,
Wire connectors with a slip-on end depending on your switch,
*Zip ties,
Fuse and fuse holder (I used a 5 amp and it works great no problems after 2 months),
*Hair dryer or heat gun if using heat shrink,
Pliers,
Screw driver.
1) Let your car cool down if you've been driving it because your engine will still be hot.
2) Disconnect your - Negative end of your battery followed by the + Positive.
3) Connect one end of the 2 wires coming out of the back of the headlight to another wire or if it is long enough directly to ground by putting on a wire connector with the O shaped end and put in on the screw like a washer. The wires coming out of the headlight are not specific you can use either one for ground or power.
4) Repeat step 3 to the other side.
5) Connect the other wire coming out of the headlight up the engine bay through a grommet and into the dash. I used an empty spot next to the cruise control button
To get to the spot where I popped out the plastic piece you have to take out a screw.
There is a connection on the back of the switch.
6) Repeat step 6 on the other side and connect the two wires together and connect them to the switch.
7) Connect a wire coming out of the switch out the grommet and connect it to the fuse holder. I just taped the fuse and fuse holder to the side of the fuse box (seemed to make sense.)
8) Connect another wire coming out of the other end of the fuse to the battery.
9) Nows the point where I went back and heat shrunk all my connectors, zip tied all my lines and double checked all grounds and connections.
10) Finally reconnect your battery.
(Pics are gone now but directions are pretty basic)
Last edited by WellFedHobo; Jan 31, 2010 at 05:55 AM. Reason: cleaning up DIY section
Apathyy
Jan 6, 2009 01:32 AM
Apathyy
Jan 4, 2009 04:32 PM
pimpossible
Oct 27, 2007 10:23 AM
lemonchai
Mar 19, 2006 07:46 PM
RaskyR1
Jan 9, 2006 12:05 PM
