We're adding and testing new features:  Create your Garage, used it? Give us some feedback here.
Go Back   HondaCivicForum.com > General Automotive > General Civic Talk
Reply
Thread Tools Search this Thread Display Modes
Old 05-31-2005, 12:54 AM
sacicons sacicons is offline
Send a message via AIM to sacicons
Default Tips and Tricks
Ok, this is a new section for odd little pieces of advice you find along the way that may help others with their projects. if you have something new, then edit your post and add it in. ONLY T&T POSTS! no comments please, lets keep this on topic.
Im not sure about the exact years, but i assume it at least applies to 5th gens, i have 00 si front and rear brakes, and the SS lines for a 00 SI were too short, and started leaking. turns out that 5th gens with brake swaps need 95 GSR brake lines, not the SI ones. they were about 3 inches too short.
To remove this ad, register today or login if you already are registered!
__________________
Yes, there's a "Replacement for Displacement". Its called Volumetric Efficiency.
Quote:
ORIGINAL: Forty04
I choose the rear ending
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 07-06-2005, 10:00 PM
KnightRiderCivic KnightRiderCivic is offline
Default RE: Tips and Tricks
here is a tip for the track....on my cold air intake i made a plastic water tight box around it with a drain at the bottom that i can open and close. and before i pull up to the line i fill it with Ice. Its before the sensor by the way. dont have any confirmed data proving its better but it sure makes me feel better...lol
by the way its around the pipe not the filter...before that question is asked.
__________________
Don't rev your motor at me unless you are will to put your money where your mouth is!
Old 07-06-2005, 10:08 PM
Street Sniper Street Sniper is offline
Wouldn't being at the track provide confirmed data? Make a run with no ice and then with ice and let us know. I have read about icing the intake manifold in line and it providing more horsepower/faster runs though I have never done it.
__________________
Tuned by G-Tech... Powered by YooHoo. Damn, I miss the Super D.
Quote:
...there's more than one way to skin the horsepower cat.
Old 07-06-2005, 10:18 PM
LEVIII LEVIII is offline
You can remove all of the stock sound deading material that is just weighing your car down by putting dry ice on it for a few miutes and then chipping it away
USE GLOVES WHEN HANDLING THE ICE!!!
Door locks on Honda Civics are negative trigger!
The bolts on a differential/final drive gear are reverse thread
If smoke is coming from you car you can tell alot about what it is by its color
White-Generally coolant burning
Blue-Generally oil burning
Black-Generally fuel
__________________
Buy your parts from........Speed6motorsports.com
pick 2: reliable, cheap, fast
Old 07-06-2005, 10:32 PM
I read that a whole write up on that because Sac told me to start there.
Total time- 20 hrs
Weight saved- 15 lbs.
No thanks.
__________________
Old 07-06-2005, 11:12 PM
Quote:
ORIGINAL: Street Sniper
Total time- 20 hrs
No thanks.
You did it and it took that long?
__________________
Old 07-06-2005, 11:21 PM
No, that's what the guy who did the write up reported. That's also what changed my mind about doing it. If it was up around 80-100 lbs I would do it, but 15?? No way.
__________________
Old 07-07-2005, 07:05 PM
Well i dropped my time by .1 in the 1/4 but engine temps were different and all that. too many varibles to say for sure until i can get it on a dyno.
__________________
Old 07-07-2005, 10:33 PM
ngoti 8tor ngoti 8tor is offline
When you change your headlight bulbs, DO NOT TOUCH THEM WITH YOUR FINGERS!
Use clean gloves or something, because the oil from your hands will cause them to blow.
Old 07-08-2005, 11:54 AM
Remmy's Avatar
Remmy Remmy is offline
Admin
Send a message via AIM to Remmy
Quote:
ORIGINAL: ngoti8tor
I dont think that apply to incandescent bulbs.
When working on the engine, try not to lie tools around the engine bay. Often times you lose track of one and or cant find it or close the hood on it... sometimes it can be very dangerous if a tool finds the wrong place.
__________________
I can run from trouble, but I prefer to run over it.
2005 Jeep Grand Cherokee LTD 5.7 HEMI
Reply
Tags
02, 2007, 4th, 91, 92, camber, change, civic, diy, gen, honda, octane, oil, performance, street, tips, tricks
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
AMSOIL - Performance Oil Technology
K&N Engineering
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for HondaCivicforum.com content, comments, or advertising. HondaCivicforum.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse HondaCivicforum.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
