We're adding and testing new features:  Create your Garage, used it? Give us some feedback here.
Go Back   HondaCivicForum.com > Your Ride > Header, Intake, & Exhaust
Reply
Thread Tools Search this Thread Display Modes
Old 05-17-2007, 07:30 PM
my05civic my05civic is offline
Default ========Exhaust FAQ========
Exhaust FAQ
Q. What's the best exhaust for my Civic?
A. There is no definite answer to this question. Everybody has different preferences.
Q: What is the difference between a catback exhaust, an axleback exhaust, and a muffler?
A: A catback exhaust is an exhaust system that includes everything you need from the catalytic conveter and back, including the resonator, piping, and a muffler. An axleback on the other hand, extends from the rear axle of your car to the bumper. An axleback includes the muffler, and a piece of piping that connects to your stock exhaust piping, providing that it'll fit. A muffler is exactly that: a muffler. If you purchase a new muffler, you'll need to cut off the old muffler from the stock piping, and go to a shop so they can weld it on to the old piping and attach new hangers.
Q: What is an exhaust tip?
A: An exhaust tip is a comestic piece that attaches to your muffler tip. Mufflers from factory are typically grey, dull, and dirty; with an exhaust tip however, your muffler will look slightly more "elegant."
Q: How many HP do I gain if I get exhaust tip?
A: Muffler tips don't add any HP to your car because as previously mentioned, they are purely cosmetic.
Q: How much are exhaust tips?
A: The tips from Honda will run your $50-$80 dollars, but for that much, you could get an aftermarket muffler that is shiny to begin with. If you choose not to get a new muffler and you do want a new exhaust tip, go to stores like Walmart, Autozone, Pepboys, etc... they'll have them in stock from $5-$30.
Q: How do I install a exhaust tip?
A: Most exhaust tips are attached to the muffler tip using a screw. All you need to do to install it is slip it on the muffler, grab a phillip screw driver, and tighten the single screw.
Q. What good exhausts are avalible for my Civic?
A. In no particular order (most listed here bolt on directly but some require custom fabrication, depending on model):
Catbacks
1. APEX'i World Sport 2 (WS2) (MSRP: $539.00)
2. GReddy Sports Performance 2 (SP2) (MSRP: $599.00 for DX | $679.00 for LX)
3. GReddy Evolution 2 (EVO2) (MSRP: $629.00)
4. Skunk2 Mega Power (MSRP: $565.25)
5. Magnaflow Catback (MSRP: $530.92 for 01-05 | $596.96 for 06-07)
6. Tanabe Super Medallion Hyper (MSRP: $630.00)
7. Tanabe Super Medallion Racing (MSRP: $630.00)
8. Tanabe Concept G (MSRP: $640.00)
9. RS*R Ex-Mag (MSRP: $559.00)
10. RS*R GT2 (MSRP: $479.00)
11. HKS HiPower (MSRP: $370.00 (axle-back) | $599.99 (catback))
12. Espelir JGT500R (MSRP: $600.00)
13. DC Sports Single Canister System (SCS) (MSRP: $551.25)
14. APEXi GT Spec (MSRP: $749.00)
15. 5Zigen Fireball (MSRP: $650.00)
16. Thermal R&D (MSRP: $564.00)
17. APEX'i N1 (MSRP: $599.00)
18. Megan Racing Drift Spec (MSRP: $379.95)
19. Invidia N1 (MSRP: $599.99)
Universal Mufflers
1. Netami Twin Loop (MSRP: $135.00)
2. Magnaflow (MSRP: $85)
Q: What's better, custom or catback package?
A: This really depends on how much you want to spend and what kind of power your looking for. If you want to spend less, custom is always cheaper. If the piping size of your choice is not available, you have no choice but to go custom. If you can only have enough money for a muffler and cannot wait any longer, go ahead and have the muffler welded on; you can always add the piping later and still have the results of a catback had you bought it in the first place.
Q: How easy is it to install a catback exhaust? Can I do it at home?
A: A catback exhaust that is designed for your car will bolt on very nicely without any modifications whatsoever. The hardest part of installing a catback exhaust is taking the old exhaust off. Many of the bolts that hold the old exhaust together will be rusted, and to get these off, one may need a dremel or an impact wrench. Not everybody has access to these tools, so alternatives include using a great deal of WD-40 and/or PB Blaster to lubricate the bolts, hoping to make the bolts easier to remove with a wrench. Once the old exhaust is off, one just needs to put the new on in. To get under the car (if a person can't already fit under it), the car needs to be raised. If this is the case jack stands are required. Using a scissor jack(s) is much too dangerous.
Q: How much does it cost to get just a muffler welded on to stock piping?
A: Should run you $30-$50 and about 30 minutes to an hour.
Q: Do they use the hangers on my old muffler or do I have to buy new ones?
A: When you bring a muffler to an exhaust shop to weld on, they will provide new hangers for the muffler at no additional charge. It is included in the labor fee.
Q: What's the different between exhaust on DX/LX versus EX?
A: The DX/LX has the catalytic converter built right onto the header whereas the EX doesn't. Because of this, the downpipes are entirely different lengths and an EX exhaust does not bolt onto a DX/LX model without custom fabrication.
Q: How do I convert my DX/LX exhaust to an EX setup?
A: If you want to use aftermarket EX exhaust parts you going to have to get the following:
1)EX aftermarket header
2)EX downpipe/cat assembly (Dezod.com carries a radom tech one)
3)EX catback of your choice
4)Your secondary O2 sensor will need to be lengthed to fit in it's new location.
Q: Should I remove my catalytic converter so I gain more power?
A: Read the sticky: The Truth About Catalytic Converters... What it basically says is that for the money and pollution that comes from replacing/removing the cat, you gain a neglectible amount of power and is not worth it.
Q: How loud is each exhaust?
A: I haven't heard every single exhaust that is listed above, but I have heard many. In the case of all exhaust, if you floor it - that is, mash the gas pedal - the exhaust will be significally louder. In MY opinion, their volumes are as follows (CLICK FOR VIDEO):
LOUD
APEX'i N1
DC Sports SCS
Skunk2 Mega Power
Tanabe Super Racing Medallion
RS*R GT2
5Zigen Fireball
MEDIUM
Megan Racing
QUIET
Magnaflow
RS*R Ex-Mag
Q: What's the legal maximum for how loud an exhaust can be?
A: 95 decibels (in California)
Q: Is my warranty void if I replace my exhaust system?
A: As long as you don't mess with the cat and anything in front of it, you're fine.
Q: What piping diameter should I get?
A: The more HP you have, the larger piping you want. On a stock 7th gen civic, the piping's diameter is
1.75". If you plan on only getting an intake, header, and make other minor performance upgrades, I suggest that you get only a 2" or 2.25" MAX. At Magnaflow.com, a chart is offered regarding which size piping one should get depending on their engine size and HP. The chart is as f
To remove this ad, register today or login if you already are registered!
__________________
Quote:
ORIGINAL: gooberguy
would you feed your baby milk bought from ebay?
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 05-17-2007, 07:54 PM
phan10m phan10m is offline
Default RE: ========Exhaust FAQ========
FINALLY! [sm=americanasmiley.gif] [sm=bananallama.gif] [sm=goodidea.gif]
__________________
www.myspace.com/phan10m
Old 05-17-2007, 08:19 PM
Kedawei Kedawei is offline
Just wanted to add, make sure to choose the right piping size. Too small and you'll create backpressure and lose power, especially up top. Too big and you'll lose velocity, losing power everywhere. I would recommend 2.5infor any Honda application. From what I have seen this diameter loses very little down low, and isversatile as it can still support larger mods later on down the road. Butat the very least I would make sure the piping is at least the same size as the exit of the header collector, or larger.
Old 05-17-2007, 08:42 PM
i used to have a civic where i used 2.5" and i lost a LOT of low end power. if i was to do it again on that civic (sold it last year), i would have went with 2" (2.25max).
__________________
Quote:
ORIGINAL: gooberguy
Old 05-18-2007, 07:32 AM
FlipHKD720 FlipHKD720 is offline
Send a message via AIM to FlipHKD720
should also add that when converting from DX/LX to EX, you will probably pull a CEL due to extneding the secondary o2 sensors wires (unless you can find the actual harness-type extension). In this case, you will probably need an o2 simulator to fix the CEL light. These can be found at www.o2simulator.com and are universal. They are wired into the o2 sensors signal to trick the ECU into tinkin everything is going perfectly with the catalytic converter. Wire the simulator between the sensor itself and the harness that goes to the ECU becasue if you screw up the wiring, all you have to do it replace the sensor, rather than wiring them between the harness and the ECU where if you screw up, it will be much harder to replace the wire between the harness and teh ECU rather than just the sensor itself. A simulator also allows you to run a test pipe or high flow cat without getting a CEL because the ECU isnt getting an acutal reading of the cats efficiency.
Someone can make corrections on taht if i screwed up, but the CEL DX/LX thing gets brought up quite a bit so it will probably be useful to add that.
Is this gonna be a sticky? I think it should be, good job on the write up My04
__________________
Old 05-18-2007, 03:02 PM
mybrokenblinker mybrokenblinker is offline
You should put in the clip of my rsr as the soundclip since mine is on a civic and that one is on an integra...just a suggestion
__________________
ROTOZEY19111 (2:40:30 PM): I bought a bigass can of seafoam TRANNY treatment
ROTOZEY19111 (2:40:51 PM): and put that in my crankcase
Old 05-18-2007, 03:43 PM
^ where's the link? that's a great idea
__________________
Quote:
ORIGINAL: gooberguy
Old 05-20-2007, 07:10 PM
Quote:
ORIGINAL: my05civic
If you're header exits at 2.25" diameter (which a lot do), 2" is going to create backpressure. I'm not sure why you lost so much. Perhaps results vary greater in lower rpms on street cars than they do on race oriented cars (such as with AC removed, and lighter rotating parts). Heavy parasitic drag may tend to show further loss down low. Dunno.
Old 05-20-2007, 09:35 PM
bks85 bks85 is offline
WOW!!! GREAT JOB DUDE!!!! That definately cleared up all my exhaust questions.......Buuuuuuuuuttttttttt to anyone who still can't make up their mind........IMO Greddy EvoII is the best lol
Old 05-21-2007, 11:48 AM
My05 i think we should look around on YouTube and find a good quality clip of each one of these exhausts. I know theres a good Mugen Twin Loop one and a nice Evo 2 one in my YouTube favorties, and then Broken has a nice RSR one. Wanna try?
__________________
Reply
Tags
009, axle, back, cost, difference, espelir, exhaust, install, integra, jgt500r, muffler, sportmax, tip, universal, what, whats
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
AMSOIL - Performance Oil Technology
K&N Engineering
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for HondaCivicforum.com content, comments, or advertising. HondaCivicforum.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse HondaCivicforum.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
