Suspension & Steering DIYs Springs, coilovers, strut braces, sway bars etc..
Shocks (Front) Installation (88-91 Civic)
Old Apr 18, 2007 | 12:10 PM
Patrick's Avatar
Administrator
Default Shocks (Front) Installation (88-91 Civic)
Just did my 91 civic front and rear shocks replacement. However, I only posted the front, because other have post a DIY for the rear already, and my method is as follow:
Once the car is on jack stand with wheel off from the car.
Remove the bolts holding the brake line to the struts.
Follow by removing the bolt on the fork of strut.
NO PIX In order for me to remove the whole unit including the fork, I have remove the lower arm nut / pin and the axle hub nut (33mm). As to how you would remove the axle from the vehicle.
After all the bolts and nuts are remove from the axle / strut, then remove the 2 nuts on top of damper housing, the shock unit will drop and remove it from the vehicle.
Remove the bolt on the fork to separate the fork from the strut.
Use spring compressor to compress the spring and remove the bolt on top of the shock, remove the damper and slide the old shock.
NOTE: remember the alignment mark on damper when reinstall, because you will not be able to turn it once the spring is un-compressed.
Reinstall in reverse order ..!
holy_civic
Jan 18, 2010 04:28 PM
spintelect
May 17, 2007 04:23 PM
kimsuprapa
Sep 11, 2006 12:57 PM
93SiHb
Sep 9, 2006 10:54 AM
mxs
Jun 12, 2006 09:46 PM
